I have tried everything I have read about how to import movies from my canon zr50 to imovie but nothing has worked. Does anyone know if it is possible?
Results 1 to 17 of 17
hopefully you have mac with an ilink port(firewire/ieee1394/dv) as that's how the camera hooks to the mac - if so it should work just like all the guides say.
My Mac does have a firewire port and I tried connecting the camera that way. The camera was not recognized. I cannot switch to USB mode on my camera when it is connected to a firewire port.
http://www.kiva.org/about -
If you set the camcorder to normal video mode with Firewire connected, iMovie should see the camcorder.
I think mine is on that list. What other options do I have to get my videos to upload to iMovie? I tried burning them to DVD disc but couldn't import them that way. I tried connecting my external Dvd burner but it's not comparble with the Mac either! Is there any option other than buying another tape based camcorder that is compatible?
The ZR50 is compatible. It is operator error or a faulty camcorder.
How can you "try to burn to DVD if you haven't captured to iMovie video first?"
External DVD burner?Recommends: Kiva.org - Loans that change lives.
Funny....really. I am smiling and it takes a lot to make that happen right now. You were actually a huge help. I had to dumb it down for myself because I assume that everything that I try to do with this *@^((*# Mac is going to be a problem But YOU were right. Operator error. There was a connection that I was not even aware of in the front of my camcorder, a door that I had never opened before (I have only had this thing for about 8 years). Once I found the right connection and plugged it in to the FireWire port iMovie recognized it!!!!!!!!! Only three days of frustration but who's counting? It's a good thing i got started on this project early.
Thanks for your help! -
A-ha! It was a Pebkac* error.
*Problem exists between keyboard and chair.
Best way to import .mts files to iMovie?
By S4Shredr in forum MacReplies: 4Last Post: 22nd Jul 2011, 14:45 -
Import via AVDC-55 to imovie '09, audio has vanished.
By sackreiter in forum MacReplies: 4Last Post: 25th Dec 2010, 13:54 -
easiest way to import footage from DVD to iMovie?
By cinclodes in forum MacReplies: 3Last Post: 27th Oct 2010, 11:07 -
canon's 24 import into fcp help!
By kmk802 in forum MacReplies: 0Last Post: 16th Sep 2009, 00:32 -
MPEG-2 video/audio to MP4 or anything iMovie will import
By quella in forum MacReplies: 9Last Post: 3rd Dec 2007, 20:07
