Hi,
I have a DVD which I ripped to the disk. I used VOB2MPG (tried also AnyDVD). The mpg file plays with no problem however if I convert it to something else the sound is out of sync. I know that there is an option in VOB2MPG that can recalculate GOP but I would like to avoid paying if I have no warranties that it would work in this particular case.
I used restream but the problem still persists. I also extracted the m2v and audio and wanted to put it together in a mkv file using mkvmerge but when I try doing so I am getting warning "Shortened GOP ... try fixing your mpg file first".
Do I have nay other options ? Is there a free soft that could discard GOP settings ?
PS. I tried adjusting the sound manually in xvid4psp but it worked in the begging of the movie and in the other parts it did not make any difference.
Thanks a lot.
Yes - just tried and no difference the sound is out of sync. Is there any other app you could recommend for me to try ?
Thanks -
no it is an old tv series. It is 10 CDs so I am putting it on my PS3. 7 out of 10 CDs sound was great only these 3 CD are giving me trouble.
So is there a way/soft to multiplex completely unrelated material (audio and video) ?
Let's say that I have audio stream copied from a TV to my computer and I have original video stream from DVD. How would I connect it together (force it to play together)?
I was trying to do this with this particular two streams but nether tmpeg nor mkvmerge were able to do this. I was getting errors or soem warning messages and the app did not allow me to join these two streams.
Video and subtitle/sound sync problems in SubtitleCreator
By ditz in forum SubtitleReplies: 2Last Post: 20th May 2011, 04:12 -
Problems reading .mts files (possibly corrupted)
By moxiecat in forum Video ConversionReplies: 24Last Post: 7th Mar 2011, 13:35 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 09:31 -
Need to expand sound file to fix sync problems
By Calidore in forum AudioReplies: 0Last Post: 5th Jul 2007, 16:53
