Hello,
I have 20 videos (*not encoded and shrinked*) that weights about 5.5GB - Every video is in length of 10 Min.
I would like to upload the videos to YouTube.
How do I need to encode and shrink the videos that will weight eventually total of 500MB?
The quality of the videos ISNT IMPORTANT (But the sound is).
Nice day!
Sarlula.
	filesize = bitrate x running time
 so you have to add up all the running time of the videos to figure out the bitrate required
 the bitrate will be comprised of both audio & video bitrate
 you can use a bitrate calculator to help you, megui has one in it's tools menu
 eg. 20 x 10min = 200 min which is 12000 seconds
 assuming an audio bitrate of 192kb/s , the video bitrate would be 155kb/s (which is very very low), if you used .mp4 container. That's the average bitrate value you would enter for the videos
 If you used a higher audio bitrate, that would subtract from the video bitrate and vice-versa
	PDR you gotta tell the person what (simple) application you recommend... :P
	I assume that pdr, as I, is interested in quality and therefore he wouldn't use any app for this job because he wouldn't do this job.
 If they're for YouTube and if they're in a format supported by YouTube, just upload them as is. They're only going to reencode them anyway to the size they want.
	But if you want to help someone, you should try to answer from practical point of view (e.g. in this case recommending a program). I was just gently reminding PDR of that, as he sometimes gives technical responses that newbies can't grasp. (No offence intended at all, PDR!)
  Re-encoding videos to play on tvBy Immortal25 in forum Video ConversionReplies: 18Last Post: 31st Jul 2011, 10:37
  Cutting videos without re-encoding?By TYLER08027 in forum EditingReplies: 3Last Post: 18th Feb 2011, 23:14
  Resizing (shrinking) Videos and Batch processingBy DVD_Noob in forum Authoring (DVD)Replies: 1Last Post: 12th Dec 2010, 17:07
  Encoding videos for internetBy macmithos in forum MacReplies: 9Last Post: 6th Oct 2009, 16:25
  Encoding Videos for an IpodBy emmgunn in forum MacReplies: 5Last Post: 7th Apr 2008, 16:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
