using AVCHDCODER to convert MKV to BD -R . I am unselecting forced subtitles in setup of avchd but a still get subtitles that are on all the time and can't be turned off. Thanks in advance for help
Thank you for your reply. I realy like avchdcoder. would like to solve this problem with forced subtitles if i can. any idea why i get forced subs even with force subtitle option is unchecked. much Thanks again for your reply
Are you speaking of unchecking it in avchd coder settings, which i had already done or is there a plugin in ffdshow to be unselected. Sorry for my confusion.
I believe doing both is better. Open "Video decoder configuration" from your ffdshow installation path and untick "Subtitles".
Of course it is possible that you have some other decoder/filter which puts the subtitles over the picture. The best way to know is to use Media Player Classic (MPC) and play your video. If it has the subtitles on - you'll need to find what's putting them there.Laugh and the world will laugh with you. Cry and you will be alone -
Yes I have had the one in avchdcoder unticked from the first time i used it. I will play the video in windows classic media player. and go from there however a am not realy sure how to approach finding it. Thank you so very much for the information.
Blu-Ray to MKV with forced subtitles - Size of file not issue
By rajsharma714 in forum Blu-ray RippingReplies: 3Last Post: 16th Nov 2012, 21:25 -
forced subtitles
By bogey219 in forum SubtitleReplies: 4Last Post: 6th Nov 2011, 21:00 -
Forced Subtitles
By sxj1704 in forum Blu-ray RippingReplies: 4Last Post: 29th Jan 2011, 08:17 -
MKV to AVI - But retaining forced subtitles...
By peejay1977 in forum Video ConversionReplies: 1Last Post: 18th May 2010, 04:00 -
Forced Subtitles Only In First Stream
By sambat in forum SubtitleReplies: 3Last Post: 28th Apr 2009, 22:05
