Subtitle not work with WDTV Media Player ?
I have Subtitle IDX But do not show with WDTV
It should work. Or else convert to srt. See http://wdtvhd.com/index.php?showtopic=12426
If you are talking about the WDTV player and not the WDTV Live player, I can tell you that SUB/IDX is not well supported. When I've tried to use SUB/IDX the player will not display about 20% of the subtitles. I convert SUB/IDX to SRT because SRT works well with the WDTV player. Also note that the movie and the subtitle file need to have the same name. For example, if your movie is MYMOVIE.AVI then the subtitle file(s) need to be MYMOVIE.SUB and MYMOVIE.IDX or MYMOVIE.SRT. Finally, you may need to use the menu after the movie starts and turn on the subtitle file.
I have 15 Movie and 15 subtitles all IDX The same name as the movie
13 shows without problems But only 3 do not work
I have WD TV HD Media Player Full HD 1080P
WDBABG0000NBK
WDTV Live Media Player & ...
By gonwk in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2011, 19:52 -
WDTV Live Media Player and the like vs. Desktop with HDMI port (HTPC?)
By edong in forum Media Center PC / MediaCentersReplies: 13Last Post: 19th Mar 2010, 14:30 -
Does the wdtv media player handle dvd pal iso files?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 12th Dec 2009, 13:34 -
New NON-Blue-Ray DVD Player or better off with WDTV Live HD Network Media?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 12:36 -
No audio from MKV on WDTV media player
By kyrcy in forum Media Center PC / MediaCentersReplies: 4Last Post: 24th Oct 2009, 14:27
