Is it possible to start capturing with VirtualDub (all the nessesary video filters selected) and feed the raw/Huffy AVI file directly to TMPGEnc using VirtualDub's frameserving or not ? If yes, can someone tell how to do this ? Or what's the other alternative similar to the above ? The reason is, I do not want to create a temp. file (~30 GB) and then encode in TMPGEnc for a VCD.
Thanks in advance
If you mean frameserve WHILE capturing, no.
If you mean frameserve the file AFTER the capture is complete, yes...
Look at http://www.vcdhelp.com/virtualdubframeserve.htm
Where can I download Frameserve ?
By DuBsTaR in forum Newbie / General discussionsReplies: 19Last Post: 9th Dec 2011, 18:47 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Frameserve on MacOS??
By Maxwellbest in forum MacReplies: 5Last Post: 4th Oct 2008, 16:34 -
How do I DeInterlace and Frameserve?
By rocky12 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2008, 21:50
