HI I am using a laptop windows 7 and my problem is that when i download video from Firefox or IE using realplayer downloader and convert them, it doesn't convert the whole video. I used any program possible including Super video converter which i have on my desktop computer. This happened recently and i was able to convert videos fully in the past until this happened. For example when i download a video which was 16min long and after when i converted it the output video was 36 seconds. My desktop is running on vista and videos i download off there and converted comes out fine. Please help if anyone know what the problem might be.
TIA
Results 1 to 11 of 11
I will try those.
Yes i know i downloaded the videos completely because i even played the video right after i downloaded them. Could it be something from my laptop that's not getting the programs to fully convert the videos?
I dont know if this will help but the videos iam converting are for my Sony ericsson phone 3gpLast edited by iviet; 17th May 2010 at 17:32.
Nevermind those did not work i guess i forgot to add about the converting them for my sony ericsson phone.
What model phone ?
What type of video will it play ?
Different phones play different types of video. You want help, then help us help you.
Xvid4PSP outputs for a number of different phones. One of them may be compatible, however without knowing what you phone can play, no-one can tell you for sure.
if you have a video that does play, use mediainfo to work out what the settings are, and encode your videos to match.Read my blog here.
Sony ericsson w580I it plays 3GP videos and sound AAC.
The videos will work after converted the problem is that for some unknown reason any converter i use does not convert the whole video. -
Yea like it wont say any errors or nothing, just says success but when i checked the file its not even the whole thing.
VCL Downloaded 1.1.11 issues
By bryony in forum Video Streaming DownloadingReplies: 0Last Post: 24th Nov 2011, 11:07 -
Converting/Decrypting Videos Downloaded From PSN?
By Startropic1 in forum Video ConversionReplies: 0Last Post: 19th Dec 2010, 14:45 -
Viewing Downloaded Videos Seeking Problem
By imdaman in forum Video Streaming DownloadingReplies: 2Last Post: 30th Nov 2009, 00:13 -
How to unblock videos downloaded from limewire
By wandj in forum Video ConversionReplies: 9Last Post: 16th Oct 2008, 04:32 -
Stuttering Downloaded Videos
By RonLuxton in forum Software PlayingReplies: 4Last Post: 4th Oct 2008, 14:36
