I have some HD movie files(.m2ts, .mp4, .mkv) that I would like to burn to a standard DVD for friends that don't have a Blu-ray player. What is the easiest way to do this? Or is it involved because of the shrinking?
I like AVStoDVD for this type thing. It is free and does a good job. If you are happy to pay, ConvertXtoDVD is another good option.
Read my blog here.
TMPGEnc Authoring works v 4 is another good tool if you want to pay. Great quality, easy to use.
avstodvd is good and I also recommend it.
Another option is if your regular dvd authoring application that you already use supports importing video and audio files seperately you can demux the files. You will still need to encode them to mpeg2 dvd standard prior to importing.
That is what is good about avstodvd. Its suite of apps does it in an automated fashion.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Has anyone else had some problems converting to dvd video from M2TS files with VC1 codec? The last one I did, AVStoDVD choked big time and would not convert it. I'm not sure if it was the VC-1 codec or if it was the audio (DTS-HD MA). I solved it by writing an AviSynth script and running HCencGUI. I demuxed with ClownBD and converted the audio separately, but AVStoDVD doesn't seem to be a foolproof solution for all such files.
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 21:39 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
MP4 or M2TS files.
By jamesj84 in forum DVD RippingReplies: 0Last Post: 21st Feb 2012, 13:57 -
How to convert MKV / MP4 to m2ts
By Bonie81 in forum Video ConversionReplies: 0Last Post: 9th Jun 2011, 14:47 -
How to convert blu-ray (m2ts) to mkv or mp4 properly?
By michaellee0101 in forum Video ConversionReplies: 1Last Post: 20th Apr 2011, 08:24
