Results 1 to 16 of 16
    Jul 2008
    I am editing a project in CS4 that was (unavoidably) shot on 4 different cameras. We used a canon xha1, hv20, 7d, and a kodak zi8. Naturally, the footage is all different and it's giving me hell. The xha1 and hv20 I know are in 1080 60i, so that is what my sequence is in. However, my 7d shoots with a huge resolution and the video jerks a bit. I re exported it to avid format and the video didn't show up in my source or program windows. The Kodak I believe records in the same crappy h.264 codec and is also giving me junky playback. If I open a sequence to fit the 7d, it will be to big for the other 2 canon cameras (and possibly the kodak).
    I'm not sure even what to ask, but I just felt like sharing my impossibly over complicated work flow.
    Edit: http://vimeo.com/forums/topic:23548 is where I got the idea to convert the 7d/kodak footage
  2. What format is your end goal? e.g. blu-ray, dvd, web ? etc...
    What format is the 7d and zi8 footage (e.g. 1080p24, 720p60 etc....) If you don't know , use mediainfo
    In order for PP to "see" dnxhd footage, it has to be installed on your system, with quicktime . To be honest, it's not that much "snappier" to edit on windows than the native footage. This is because anything stored in .mov container is poorly optimized on PC. Cineform is much faster, but unfortunately, not free
    Jul 2008
    My final output will be 1080p 29.9fps meg2 mainconcept and I already have dnxhd installed
    zi8 is 1920x1080 29.9fps mp4a: MPEG-4 AAC LC codec
    7d is the same, but with sowt: 16-bit signed little-endian codec
    I might also add that the 7d and hv20 are mine, but this is my first real project (not just on test shots) with the 7d
    Edit: I just waited on a 20 minute render w/ clips from all cameras. Everything has decent playback with the exception of the 7d footage. It looks strange (almost compressed)
  4. Originally Posted by pjcom View Post
    what do you mean compressed? do you mean bitrate/size wise, or do you mean levels or gamma conversion
    how did you do the conversion to dnxhd? One thing to be aware of is a levels and gamma shift that premiere does with dnxhd/mov as it converts to RGB internally
    There's probably several ways to do this, and it will depend if you favor speed vs. quality.
    Since your format goal is 1920x1080p30, I personally would deinterlace and resize the 1440x1080i60 hdv footage to 1920x1080p30 using 3rd party deinterlacer in avisynth (premiere is horrible for resizing and deinterlacing quality wise). The intermediate you could use is dnxhd also (so everything now would be 1080p30 dnxhd). I would use a custom sequence setting for all the footage (1920x1080p30, which matches your export settings). The negative to this is your hdv footage will now get yellow/red render bar , and will be converted to RGB internally (usually not an issue, as hdv is easy to decode, and you usually convert to rgb anyway when adding filters, color correction etc...) , and of course time taken to encode to the intermediate
    Jul 2008
    there is a small "ghosting" that occurs in the rendered native 7d footage. The converted footage did not work right, I am sure I messed something up there.
  6. ghosting implies you did a framerate conversion, or did some other processing like blend deinterlacing
    again, how did you do the conversion (e.g. though AME, ffmpeg, mpegstreamclip etc...)
    look with mediainfo and check the specs are the same (1920x1080p30 before and after)
    (by the way, when i say 1080p30 i really mean 29.97 fps)
    Jul 2008
    I am using the native file, friend. I converted nothing. This is the file I pulled off my compact flash card.
    I think it is going to come down to having to render a lot. Thanks for your input about the using the custom sequence!
  8. are you seeing the ghosting in quicktime player by itself? if so, what were your camera settings, shutter speed - because this would suggest it's in the original file, not by premiere interpreting the file
    Depending on how you view it or interpret the file in PP, or adjust with speed changes, you can get ghosting.
    if you put a 1920x1080p29.97 native 7D clip in a sequence with the same settings, you shouldn't get any ghosting
    Jul 2008
    in quicktime by itself it is slightly jerky unless i "flatten" the file by saving as a separate self contained file.
    I understand that "jerky footage" is common amongst 7d users b/c of the bad h.264 codec it records in.
  10. "jerky" is a world different than "ghosting". Make sure you are describing this correctly. Ghosting is a blend of fowards and backward frames, so you get a double image of sorts.
    jerky is usually from slow/old computer or poorly optimized software for playback , but can be from duplicated frames due to framerate conversions / speed changes done in your editor
    h.264 isn't bad per se, it's just that the software isn't well multithreaded for the .mov container on pc platform. Quicktime is one of the worst players available. The h.264 implentation of the 7d is poor also, it uses a very low quality profile, but at least it uses a high bitrate to compensate for these deficiencies. But in turn, a higher bitrate is more CPU intensive for decoding - which makes it harder to edit... a vicious circle
    for example re-wrapping it into a .mp4 container and using better software decoder like ffmpeg in mpchc makes it play back just fine (even on older computers), even though the actual video stream is identical
    Jul 2008
    I understand the difference my friend. I have been futzing with filters and effects for about 8 years now. It is indeed creating a small "ghost" like feature as well as a jerky feature while unrendered. However, it seems to be minimized after a render. My problem was that the bar above it was yellow, and the clip will not render until I have to render another clip with a red bar (go figure?!). I am not sure to why this is. Fortunately this is a music video type project and I can live with the produced effect. (in fact it might make it more appealing)
    "the software isn't well multithreaded for the .mov container on pc platform"
    Couldn't agree with you more. I am a PC user and I run into all sorts of platform issues. I happen to like h.264 myself (i like the output quality and compression size), but I tend to be add it to my laundry list of issues and complaints on dealing with different codecs. Once I get the money I am investing in a Mac laptop simply for file conversion use. (i.e. when I receive a file that was captured on a mac that I need to edit on my PC)
    This project has a deadline coming up and I seem to be working around my issues atm. But, in the future, I am going to try taking the 7d's footage and play with the output from Mpeg Streamclip and whatnot. I also happened upon a copy of Neocene. I need more extensive testing with the resulting conversion to avid/avi/mov/misc other output formats.
    This is my FIRST real project with my new 7d, and ironing out my work-flow kinks is going to be a priority for me (lol after I finish this project).
    as a side note... while I saved time avoiding a real-time capture, I made up for it by encountering other issues.
  12. If you're seeing this in the native footage (you can use another player like kmplayer or smplayer for example) , then likely it was shot with problematic settings (like bad shutter speed). If you see it in premiere, it can be due to a number of things depending on your settings.
    If this is the type of thing you are going to be doing a lot , I would spend the money on CS5 and a proper graphics card. The mercury playback engine makes everything smooth , even several layers of 7d footage (or other kinds of h.264, even AVCHD, or 4K footage) with effects in realtime without rendering. This is truly amazing. Some people have "coaxed" the MPE to work with "lower end" , less expensive cards (instead of quadros, or top end consumer cards) through registry hacks. It really is the fault of software optimization and being able to leverage CUDA acceleration. A $1000 dual core system with compatible card is easily 10x faster editing/scrubbing on CS5 than an $5000 dual quadcore workstation editing on CS4 or unoptimized software. No joke.
    Still, using 10-bit intermediate (such as cineform or dnxhd) can provide other benefits than "speed of editing". You get much less banding when you do levels / gamma adjustments with higher 10-bit precision, even if your export format is 8-bit. "v210" is uncompressed 10-bit 4:2:2 , and another option as well. You need fast I/O (e.g. SSD's , RAID0 HDD's ) in order to work with this because of high data rates.
    Jul 2008
    I am in the process of saving up for CS5
    As far as system goes, I am running SLI with a GB of video ram and 6GB of DDR3 (soon to upgraded w/ the addition of CS5), and an overclocked 2.6 i7 processor. It just "Grinds my gears" whenever these things happen. I truly appreciate the info and advice.
  14. Member fitch.j's Avatar
    May 2009
    This is really interesting and something i want to look into. Not because i want to force it work with a lower card, just that I understand it would work with a GTX 285 but not a 295 like i have in my second system. If i can 'coax' it into working with it and using all that power thats in there then i definately will put cs5 on it.
  15. Originally Posted by fitch.j View Post
    http://www.dvinfo.net/forum/adobe-creative-suite/477968-how-make-premiere-cs5-work-gtx...-200-gpus.html
    Cheers
  16. Member fitch.j's Avatar
    May 2009
    Interesting!.....Installation has commenced!....
