Hello!
I have a movie which has three different audio tracks playing in different language. I'm using Any Video Converter to convert to avi format. It only allows one track at a time. Is there any way to keep all three audio tracks?
Question 2:
This question concerns subtitles.
The video is over 2 gig in size, so I want to break it down. It has a ".idx" and a ".sub" file. I want to break the video into two segments. How to I divide the ".idx" and ".sub" files so the final two videos are in sync with the subtitles.
Thank you all in advance!
Apparently not with this Any Video Converter. VDub(Mod) can do it. Take the AVI you have with one audio track and add in the other 2. Make sure to set the video to Direct Stream Copy so it isn't reencoded.
Find out the exact lengths of part1 and part2. Those are your split points. Then use the VobSub Cutter utility included in the VobSub package to do the splitting.How to I divide the ".idx" and ".sub" files so the final two videos are in sync with the subtitles.
Program for converting DVD to Xvid with 3 audio tracks ?
By Noahtuck in forum Video ConversionReplies: 2Last Post: 27th Jun 2010, 01:17 -
Converting to MKV plus adding diff Audio & Subtitle tracks
By evile1690 in forum Video ConversionReplies: 3Last Post: 5th May 2010, 01:37 -
Converting two audio tracks to one stereo track in Sony Vegas?
By Great Googly Moogly in forum AudioReplies: 8Last Post: 12th Apr 2010, 03:49 -
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 03:09 -
Converting .ogm to mpeg-4 with subtitles and multiple audio tracks
By Weasel3689 in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2009, 12:34
