Hello, I am new to this forum and video encoding and I recently downloaded DivX Plus Converter.
However I am unable to use some of the options such as "Custom Resolution" , "Limit file size" etc..
Those options seem to be disabled. I am not through the 15 day trial period and so I cannot figure out why those options do not work. I have also tried using several different files but to no avail.
I have attached a screen shot to illustrate the problem.
Yeah that is odd, because it says right on their website that you can unlock the "Pro features" on a fifteen day trial period (as you described).
Perhaps there's also a limit on the NUMBER OF TIMES you can use the Divx Converter's "Pro features," in addition to the 15 day limit... -
good divx converter
By bigmacsexgod in forum Video ConversionReplies: 12Last Post: 19th Jan 2010, 14:35 -
Divx Converter Problems
By Maritimer in forum Video ConversionReplies: 11Last Post: 18th Dec 2009, 14:00 -
Divx Converter
By jrodrigu123 in forum Video ConversionReplies: 2Last Post: 10th Dec 2009, 19:14 -
divx mobile converter
By sarmin in forum Portable VideoReplies: 1Last Post: 24th Mar 2008, 21:56 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28
