Hi there,
I feel this PC is a bit cluttered up with codecs.
K-Lite codec pack being one of them which i have been reocmmended to stay away from (just havnt yet uninstalled it as i wanted to check here first!)
Basically i mainly play XviD/DivX and .MKV files.
Can you lot please tell me what video players and codecs are best to handle DivX/XviD and then .MKV and also what the NEEDED codecs are?
A lot of the MKV files have AC3 Audio so what am i best to use for that?
Am i best using MPC Home Cinema for .mkv files? (H264)?
Thank you.
	I use MPC-HC most times for MKV, but I also have Zoom Player and VLC that handles them with no problems. VLC can struggle with MKV HD video if you don't have a fast computer and video card. Probably what I would recommend is trying ffdshow and it should decode most all what you watch. It's not a codec pack, so it rarely causes problems.
 I also have the Divx and Xvid codecs installed, and they don't seem to conflict. MKV is often H.264 with AAC or AC-3 audio. ffdshow should work for that also.
	Since you have K-Lite, it should have installed "Codec Tweak Tool" on your Start menu.
 Select "All options" and you can choose to detect codec conflicts, activate or deactivate any codecs.
 You can deactivate any codecs using this and if you find you need them later, reactivate.
 You can probably just have ffdshow and Haali splitter active.
  Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 11:27
  What are the exact requirements for a video to be AVCHD complaint ?By ahmadka in forum Authoring (Blu-ray)Replies: 4Last Post: 1st Jun 2011, 20:24
  AViSynth to display two video files in sync: specific requirementsBy a1s2d3f4 in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2010, 13:59
  Minimum PC Requirements to do HD Video Editing?By dan1st in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2009, 19:29
  Specific video card requirements for HD playback?By GLE3 in forum Newbie / General discussionsReplies: 17Last Post: 1st Apr 2009, 13:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
