Its been a while since I last post. (Feels like confession at church).
I have about 25 pictures that have a geotag. Is there a way to create a video with the pictures that will show the location of the pictures (on a map)? Something like a slideshow. I apologize if my question is not too clear.
When it sounds too good to be true, it usually is!!
The easiest way I can think of is to input the LAT/LON into something like Google Maps, take a screenshot, then add that to the slideshow.
I see, besides a screenshot, what software do you recommend for screen capture like those used for video tutorials?
When it sounds too good to be true, it usually is!! -
Thanks guys,
Will give them all a try.When it sounds too good to be true, it usually is!! -
I input the LAT/LON in Google Maps, get the view I want, then resize that with the browser size control to about 80%, or whatever works so you can see the full map, then just use the prtsc key on the keyboard, then open in MS Paint, resize by pixels and trim as needed, then output as a .jpg scaled to my slide size. The Google Earth program may give you more options, like 'flying' to the location if you want some animation.
Probably lots of other ways, but I don't do this too often. You could also use PowerPoint if you have that and want a more dynamic presentation. The freeware Open Office may have a similar program.
There are other screen capture utilities here: https://www.videohelp.com/tools/sections/desktop-screen-capture But prtsc and Paint works for me.
How to Split Video/Pictures as seen on TV
By HoosierGuy in forum EditingReplies: 13Last Post: 19th Dec 2011, 15:49 -
Create a video from several pictures
By snewt in forum ProgrammingReplies: 1Last Post: 29th May 2011, 19:45 -
What is this video defect? (pictures)
By timmus in forum RestorationReplies: 2Last Post: 23rd Dec 2010, 10:34 -
Looking for software - pictures into video
By jsdn in forum EditingReplies: 8Last Post: 20th Mar 2010, 11:59 -
video from pictures
By alintatoc in forum ComputerReplies: 2Last Post: 20th Mar 2010, 08:22
