  1. Anonymous
    Guest
    My pc and makemkv recognizes the hd-dvd in my attached 360 hd-dvd drive.
    When I "makemkv" it produces an 87mb file that is a short spattering of scenes from the movie.attached is the output log.am i doing something wrong or is the disc non-makeable?
    Jun 2004
    California,United States
  3. Anonymous
    Guest
    thanks
  4. At the MakeMKV website, nowhere can I find an explicit statement that HD-DVD is supported. (I know what the description of MakeMKV in the tool section over <-- *there* says.) Anyone know for certain?
    Pull! Bang! Darn!
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    It doesn't support all hd-dvd and I doubt they will fix it.
  6. Anonymous
    Guest
    I went over to the mkv forum and was told it essentially doesn't support hd-dvd.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I have removed hd-dvd from the makemkv tool description now.
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    @dr gee - I don't mean to insult you at all but you did rip the disc to the harddrive first right? I don't know if that will make a difference with makemkv or not.
    But as I mentioned in your other thread you are better off to use ripbot264. I know that works with hddvd.
