As you can tell by my sig, it's mostly stock(Compaq sr2170NX) and I tried to replace the CPU, cpuz shows a Intel P4 631 ceder mill at 3gz and since its a socket 775LGA (motherboard ECS, Alhena5) I tried to put in a Intel Pentium D 940 3.2 GHz/4M/800 SL95W and that seemed to help some in my gaming, I was able to increase a lot of the video effects without sacrificing any fps. Here is my question, I have 2G of what i thought were PC5300 DDR2 which stated it was 667 mhz but on cpu-z it shpws the memory at 333 mhz. Am I missing something here? I only bought this to wring out as much performance for my comp to play WOW. Any help would be appreciated! You all helped so much before on my previous question, I thought I wold just shoot this out there and see what others might show on theirs if they had a similar setup.
those numbers are fine. ddr2 is accessed twice per clock so the 333mhz is correct.
Will my pc run W7 32bit?
By neworldman in forum ComputerReplies: 6Last Post: 20th Oct 2010, 15:42 -
where is RUN on Windows 7?
By jyeh74 in forum ComputerReplies: 7Last Post: 17th Dec 2009, 19:00 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 07:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 15:31
