I no longer have the original video shot in High Definition on a Panasonic HD camcorder. I converted the video to AVHCD so it could be burned on a DL DVD. That completed, I would like to move the video to a blu-ray disc.
Given the current AVHCD, how can I "convert" to blu-ray format. If I've lost the ability to keep the higher definition video (from HD to AVHCD), that's not a problem. I would just like the video to be moved to blu-ray disc and would, of course, like it to be playable in blu-ray players.
Thanks in advance!![]()
I would imagine whatever bluray authoring app you use should have a built in avchd import option. Assuming that to be the case you should be able to simply locate the avchd folder on your harddrive and build from there. Since dvd burning apps like tmpgenc dvd author 2 and newer let you import dvd folders from your harddrive I have to imagine a similar option exists for the bluray equivalent of avchd.
If not you can always demux the h264 and audio and import seperately. Tsmuxer or multiavchd should do just fine for that application.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
What do you mean you 'lost' when you converted the HD content to AVCHD? AVCHD is also HD up to 1920x1080.
multiAVCHD will let you import the AVCHD folder and get it in Blu-ray format in less than one minute, without any touching of the original video.Laugh and the world will laugh with you. Cry and you will be alone
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Issues authoring Blu-ray disc from captured footage
By SportsorDeath in forum Newbie / General discussionsReplies: 11Last Post: 21st Feb 2012, 11:10 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 10:37 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
