hi,
...i've been using the hauppauge win TV pvr 150 to capture video from a camcorder 8mm.
...most of the captured video was fine; but some has annoying glitches.
...what is this caused by?
...and how can i prevent this from happening?
...i'm including a small sample video of the glitches so you can see what i mean.
thanks,
janaka
Your tape have weak/unstable vertical synch and the capture card is sensitive. Some Hi8/Digital8 camcorders have TBC feature and can fix these errors. Another way to solve the problem is to put external TBC between the camcorder and capture card, or to try other capture cards less sensitive.
...thanks much for the replies.
...i probably should mention a couple of things:
...the way i have it hooked up is that i have the video/audio out from my camcorder going to the video/ audio inputs of my tv.
...so i'm using it as a monitor.
...and the video looks fine on the 'monitor'.
...then i have the video/audio outputs of the tv going to the inputs of my haupauge video capture card.
...when i go to capture, the video on the capture software's preview window shows the glitches.
...i checked to see what TBC was and found a very informative page: http://www.questronix.com.au/info/info_tbc.htm
...would it help at all to go directly from the camcorder to the capture card?
janaka -
Thats because the capture card is more sensitive to time bases errors, TV is less sensitive....the way i have it hooked up is that i have the video/audio out from my camcorder going to the video/ audio inputs of my tv.
No....would it help at all to go directly from the camcorder to the capture card? -
captured some video
By the_man_one in forum Capturing and VCRReplies: 10Last Post: 19th Aug 2011, 05:42 -
Glitchy MKV files in Media Player Classic Home Cinema
By djdust in forum Newbie / General discussionsReplies: 1Last Post: 23rd Feb 2011, 17:45 -
captured video with hauppauge card... video looks blurry
By granturissimus in forum Capturing and VCRReplies: 4Last Post: 2nd Feb 2011, 07:43 -
Captured Video Out of Sync
By tumaz in forum RestorationReplies: 1Last Post: 9th Jan 2008, 20:55 -
Eltax dv-251 video glitchy using USB
By Diego123 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 4th Jan 2008, 10:12
