Is there a software method to keep my captured DV footage from splitting at each start/stop of the camcorder? I am copying a few DV tapes to my HD via USB using WinDV. Since the clips are very short & numerous, I hate having to join each AVI file before I can encode to MPEG-2. I will not need fancy edits, just some cut & splice.
Am I missing a setting in WinDV that makes it start a new file name for every start/stop of the camcorder ? Should I use a different capture software ? I use Canopus Edius to edit. Is there a batch import that I am missing ?
BTW, I HAVE changed the setting in WinDV so that there is no file splitting at a certain size, so that's not it.
What am I doing wrong ?
Bob Andrews
Problem splitting mkv files
By Sennaista in forum Video ConversionReplies: 8Last Post: 5th Jul 2012, 21:57 -
Splitting video files
By higgins327 in forum EditingReplies: 2Last Post: 13th Apr 2011, 14:36 -
Splitting Mpeg-2 DVD files..
By Veepa in forum EditingReplies: 2Last Post: 11th Mar 2010, 04:25 -
Splitting AC3 Into Seperate Files
By travelagent73 in forum AudioReplies: 4Last Post: 19th Aug 2009, 13:46 -
Splitting AOB files
By DeadSirius in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2008, 15:35
