I am new to this great program! I am successful at most steps in taking a blu-ray movies and shrinking it down to BD-9 except for the step of choosing the right stream.
On several disks, there are two streams that appear identical in length. They have listings of chapter that are close but not identical.
This is my biggest issue, what steps do I need to take to determine the correct stream? In the case of BORAT, I ended up burning the DVD with the directors cut which included commentary. I would love to know of a technique that I can test or view the chosen stream to make sure it is the correct one before I burn it or better yet, shrink it. That takes so much time and then to have the wrong one is frustrating.
Once you have Movie Only Mode selected, and have the m2ts file showing in the main window of BD-Rebuilder, right click on the video and you will get an option to "Preview this item". That will start the movie in Media Player Classic (presuming you have one of the latest editions of BD-Rebuilder). You should be able to tell very quickly if you have the one with the director's commentary or not.
Converting Blu-Ray movie with BD Rebuilder
By tarzan54 in forum Blu-ray RippingReplies: 2Last Post: 11th Jan 2012, 22:31 -
BD Rebuilder Movie Only Problems!
By kings322 in forum Blu-ray RippingReplies: 18Last Post: 1st Jun 2010, 06:11 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 02:13 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 04:37
