I’m having an issue when creating a mkv file. I am creating the file using Handbrake. I am also making it so it has two audio tracks, Korean and English, with subtitles. For some reason the when I go to switch between the two audio tracks they both say they are English. Is there a way to rename the track so when you look at it in media player it says Korean?
Tried mkvtoolnix? Use the mkvmergegui, open the mkv and see if you can rename audio tracks. Save as as new mkv.
Not with mkvtoolnix, but YES. Try yamb / mp4box. The metadata that designates stream language.
How to edit MKV data without remuxing (change default audio, rename lang)
By spycam in forum Newbie / General discussionsReplies: 10Last Post: 28th Jul 2015, 04:54 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 19:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
