So I am following the guide to add subtitles to a movie (the original has 1 Japanese subtitle and is 16x9 video) - I know for a 16x9 movie I am supposed to add two subtitle streams?
I have English subtitles that will replace the Japanese subs.
So I add two English sub. streams (they are the same) in Muxman (first "wide" and then "LB").
I add back the original Menu in VOBlanker and everything goes well.
I open the finished project in PGCedit and there is only one subtitle stream showing, thats ok I know because when I click the green reel icon it should come up and tell me that it actually found two subtitle streams and it has set to two streams but instead I get nothing?
So right now I only have the one stream set at "0-0-0-0", to show the subs on a 4x3 TV don't I need another stream that should be "0-1-1-0"
There's a link in the guide to my post on how to 'turn on' the new subs, a link you either didn't see or saw and didn't follow correctly:
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD?...=1#post1685800
You open the substream 1 (the second one down) that says 'none' at the moment, set it for 0-1-1-0, 'OK' back to the main screen, and then do the green-reel-of-film thing to increase the substream count. 'Save' after completing it and test before burning to disc. -
Ahh great, thanks - I missed that link originally (I had just printed it out) - thanks again!
AVI with subtitle stream - Now Possible?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2011, 10:23 -
multiAVCHD shows only External subtitle after rendering the rest not show.
By JackyWang in forum Authoring (Blu-ray)Replies: 0Last Post: 23rd Aug 2011, 10:04 -
PGCEDIT subtitle colors?
By kpic in forum SubtitleReplies: 6Last Post: 5th Jul 2010, 11:24 -
PGCEdit shows blank previews
By thief_ in forum DVD RippingReplies: 3Last Post: 3rd Jun 2008, 05:54 -
PGCedit lost my subtitle
By AlanHK in forum SubtitleReplies: 6Last Post: 31st Jul 2007, 13:53
