Does anyone have a guide on how to do a blu-ray backup "Movie Only" with forced subtitles? I found a few different methods by googling, but none of them are written "for dummies" like me (haha). I am trying to do 2012 right now using HDDVDBluRayStreamExtractor, BDSup2Sub, MultiAVCHD and possibly tsmuxer. MultiAVCHD is transcoding now but it's taking like, 10 hours. UGH!
I generally use BD Rebuilder to do movie-only backups. But, how would I get the forced subtitles with that program? It's not as easy as clicking a subtitle like you can a dvd. The forced subtitle is embedded into one of the streams and you have to get it out and re"marry" it to the video. I don't believe bd rebuilder can do this, unless I'm missing something.
In BDrebuilder setup select English as your only subtitle language and don't check the "one track for each language". I did 2012 and had no problem. I did have problems with Star Trek I and the Day The Earth Stood Still.
OK... quick question, if I decide to do a "Full backup" instead of movie-only mode, would the forced subtitles work then? If so, I was looking at BD Rebuilder with 2012 ISO loaded and I clicked "Full backup" and it only selects a couple of the subtitle streams by default. Do I leave that alone... or click on all subtitles? There are 3 or 4 english subtitle streams.
Blu-Ray to MKV with forced subtitles - Size of file not issue
By rajsharma714 in forum Blu-ray RippingReplies: 3Last Post: 16th Nov 2012, 21:25 -
Help extracting forced subtitles from Sherlock Holmes (2009) blu-ray
By vtpeters in forum SubtitleReplies: 10Last Post: 14th Feb 2012, 17:32 -
Forced subtitles english Blu Ray Avatar
By Modify_inc in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 22:31 -
No forced subtitles on blu ray rip
By dreborn in forum Blu-ray RippingReplies: 2Last Post: 26th Oct 2009, 16:55 -
Forced Subtitles in M2TS - Blu-ray Ripped to HDD
By saber001 in forum Blu-ray RippingReplies: 4Last Post: 23rd Mar 2009, 06:14
