All of a sudden, after several successful rips, RipBot stopped creating an output file (after 4 hours of churning). Digging into the logs I that RipBot can't get the audiostream out of C:\temp\RipBot264temp\job1\job1.avs That file is present, but is only 1KB. Should it be more? How could this have happened?
Relevant section of logs:
Code:C:\>"C:\Users\jsharpe\Desktop\RipBot\tools\bepipe\bepipe.exe" --script "import(^C:\temp\RipBot264temp\job1\job1.avs^)" | "C:\Users\jsharpe\Desktop\RipBot\Tools\enc_aacPlus\enc_aacPlus.exe" - "C:\temp\RipBot264temp\audio.aac" --lc --br 262144 --mpeg4aac *************************************** BePipe by dimzon *************************************** Script used: # BEGIN import("C:\temp\RipBot264temp\job1\job1.avs") # END Scanning for Audio Stream... ERROR: Can't find audio stream! ******************************************************************** * AACPlus v2 Encoder (using Winamp enc_aacplus.dll and nscrt.dll) * Coding Technologies encoder 8.0.3 * Build Oct 10 2009, 16:03:17 ******************************************************************** Input file must be WAV PCM!
Results 1 to 1 of 1
Ripbot audio problem
By neto691 in forum EditingReplies: 1Last Post: 4th Oct 2011, 18:53 -
Ripbot audio question
By neo179neo in forum Blu-ray RippingReplies: 1Last Post: 27th Apr 2011, 08:00 -
Ripbot's Audio profiles
By thezanny in forum Video ConversionReplies: 0Last Post: 18th Mar 2011, 20:51 -
Ripbot Audio Level
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 20th Nov 2010, 13:03 -
RipBot with 2 Audio Tracks??
By elJorda in forum Blu-ray RippingReplies: 15Last Post: 28th Feb 2009, 04:54
