  1. Senior Member c627627's Avatar
    Kansas
    Does anyone know how I can make sure the following setting stays on permanently, I keep having to manually select it every time because it switches to Aux whenever I start the ATi Multimedia Center
    Windows XP > Sounds and Audio devices > Volume TAB > Advanced... button > Options > Properties > Recording > OK:
    _____________________
    Intel i7 920 [200] BCLK x 19 = 3.80 GHz @ [1.4000] CPU Voltage & [1.35000] QPI/DRAM Uncore Voltage, Batch 3836A394
    3 x 1GB G.SKIL DDR3 1333 (PC3 10666) [DDR3-1691MHz] 10-10-10-24 @ 1.64 DRAM Bus Voltage
    ASUS P6T Deluxe v.1 [LGA 1366 Intel X58] BIOS 1606
    Thermalright Ultra-120 eXtreme 1366 RT with 120mm Scythe S-Flex F fan
    ASUS EAH4850 TOP Radeon HD 4850 512MB @ 680 MHz GPU & 2100 MHz Memory
    OCZ Agility 60GB SSD
    Asus Xonar DX sound card
    Antec nine hundred case, two front 120mm fans, one back 120mm Fan, one top 200mm fan
    Corsair CMPSU-750TX 750W
  2. Senior Member c627627's Avatar
    Kansas
    It turns out software when started can change that setting. In this case ATi Multimedia Center changes Windows audio input, but it can be adjusted:
    ATi Multimedia Center > Setup > Display TAB > Initialization Wizard... > Change default Audio Input.
