I film with the Canon XL II, but I'm contemplating getting the 5D Mark II for my B roll footage. I normally film set to 60i on the XL II... will I be able to mix the footage together and burn on to a DVD. If yes, then how?
Won't intercut nicely unless they release the 720p60 firmware, which there are rumors around of
The problem is 1080p30 has only 30 samples per second, and your 60i footage has 60 samples per second. It's easy to convert 60p footage into 60i for your NLE, but you cannot generate motion samples very easily when that data wasn't there in the first place with 30p footage. So the extra samples are either blended, or duplicated to get the new frames (you get blurry or choppy playback) . You can use motion interpolation software to generate the inbetween samples, but they have issues with artifacts and slower to process
The 7D and T2i have a 720p60 mode -
Or you could shoot your 5D B-Roll at 23.976p (using appropriate camera stabilization and depth of focus), then telecine to 60i.
This is what most 5D users do. They are going for that film look.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
How to get 10 hrs SD footage onto BD?
By ruffhouse in forum Authoring (Blu-ray)Replies: 52Last Post: 16th Nov 2011, 14:25 -
backing up footage
By JJJewel in forum Video ConversionReplies: 5Last Post: 25th Oct 2009, 08:26 -
Any hope for this footage?
By wwaag in forum RestorationReplies: 4Last Post: 13th Sep 2009, 14:06 -
Footage Download
By josel in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 17:54 -
Video Footage, Rotating the footage.
By nikon1898 in forum EditingReplies: 2Last Post: 14th Jun 2007, 05:54
