Hi All, Newbie here ... and very green so please be gentle with me !!
I have been trying to back up some films recorded on my digital tuner with hard drive onto DVD's for safe keeping.
The programs recorded all appear to be in TS format, I have used a whole array of conversion programs - Imgburner, Avidemux, AVS4you etc etc and tried burning the resulting files on to DVD with Windows Player, Nero, DVD styler etc but nothing would read in Alba 108 DVD player !
Eventually I started from a clean file, converting it into an AVi (with Auto GK) and burned the file onto my DVD-RW (with CDBurnerXP), all appeared to be fine and this time, I checked that I can play the resulting DVD on my PC first - which it did, then I remembered that I have a portable DVD player that the kids use in the car, so tried that - and it played ! But put the disk in my Alba DVD player and it just spins round and keeps saying 'load disk' arrgghh !!
Is this a problem with my ALba DVD player or just that the file format or type of DVD are incompatible ???
Help - Oh and please treat me like an idiot (I am one where techie things are concerned !!)
Some players are picky about DVD type (+R, -R). You have to check specifications for your player as to what type of disc is recommended. Some players will not play RW disc alt all.
Other problem could be brand name of the disc. Try to get some Verbatim disc and see if it help.
Avi(xvid) problems + dvd player
By sgbd in forum Video ConversionReplies: 1Last Post: 20th Nov 2010, 12:53 -
Connecting DVD player through HDMI: 2 Problems
By Markaveli in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Aug 2008, 07:40 -
Norcent DVD player, ask's for language problems...
By MagikLair in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2008, 15:32 -
Advice needed for Recording using Alba DVD recorder
By rhicel in forum MediaReplies: 2Last Post: 13th Mar 2008, 11:26 -
Alba dvd382stb
By djmagnifique in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jun 2007, 18:10
