I made a MKV file from a recorded HDTV TS file and then made a Quick DVD with SVCD2DVDPRO. The MKV file plays back smoothly in MPC HC but the video when the DVD is played is erratic and shows jerky motion like it is dropping frames. The original file was interlaced and I converted it to MKV with Handbrake using the default decomb filter.
Can you try using the AVSWrap feature to see if that sorts it?
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
MKV framerate/Sync issue
By dragonkeeper in forum Blu-ray RippingReplies: 0Last Post: 14th May 2009, 23:14 -
mkv framerate issues
By Eric998765 in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2008, 02:34 -
Help keep 5.1 sound for mkv-avi conversion for Xbox Media Centre playback
By HitcherUK in forum Video ConversionReplies: 5Last Post: 23rd Oct 2007, 03:30 -
Framerate conversion question (AVI --> DVD)
By kmmoore in forum Video ConversionReplies: 3Last Post: 19th Oct 2007, 09:47
