i am confused to the maximum! i have a GoldStar DV471NC CD/DVD Player (from WallMart) and i would loooooove to play my .avi movies on it...i know that you have to convert those to .mpg and then burn it using nero and i did all that but when i put it in my player it says "DISC ERROR".....then i start screaming on top of my lungs basically...the reason why i have this dvd player is because i want to play these movies on it...i would appreciate any help and thank you in advance; if anyone knows anything about this player...good/bad please let me know so i can return it (i have a month from now to return it)??? thanx a lot everyone!
Results 1 to 20 of 20
In most cases, you cannot just save mpeg files to a disk. They must be saved in a VCD format. Also, my Sony DVD drive (although it states that it can play VCD disks) will only play them if I burn them on a CDRW disk.
HTH,
Bob -
the reason why it cant is because it does not support cd-r vcds.
hey again
i forgot to say that my dvd player (as it says) supports cd-r, cd-rw, mp3..don't recall it saying 'vcd'...does it make a difference if i want to make a vcd? is cd-r, cd-rw,mp3 enough to support a movie which is created by nero---vcd or svcd? i'm sorry if i'm confusing all of you
I have not done any SVCD disks, but the .avi files that I have successfully burned to a VCD have the following characteristics:
originally the .avi files were 720X480 44100 khz
You must format them as a VCD:
352X240 44100 khz
I am sure that Nero offers a template for this. If not there is a freeware product TMPEGnc that I have used with great success.
Bob -
so you don't have to convert .avi to .mpg????? in order to watch them on a standalone dvd player???
You don't have to convert your avi to mpeg if you are useing Nero 5.5
If you select vcd from nero then find your avi and drag it to the bottom. Nero will encode it for you. Granted it is slow but it encodes it and writes it to cd for you. If you've already encoded it to an mpeg then drag your mpeg there instead of the avi file. -
REALLY?!!!!!!!
you're kidding me?! oooooo my god i love you..you just saved most of my nerves !
THANK YOU..!!!
.one more thing.....if on my standalone player it says that it can play CD-RW AND CDRs and Mp3s.....will it play vcds???????
does it HAVE TO STATE that it playes VCDs like on some standalone dvd players?????
THANK YOUUUUUUUUUUU GUYS SO MUCH!!!
Dude you might wanna give up now, having looked at the other two models that this company make, it doesn't look like they support vcds. Sorry to bring you the bad news
no, it's allrighty that's what i want to hear 'cause ...then i return it....while i still can
thank you....
so i gotta take one that states that it PLAYS VCDS?
thnx
p.s. it's "dudette" eheh
Strange, I though all DVD support VCD !Originally Posted by bilbogod
Most people own a pioneer or Apex basically played all type XxsSVCD -
Guestsome only play CD-R or CD-WR not both. OH! if you return get one thatOriginally Posted by Beauty
will play MPEG files. They do make them -
..well i guess if it says on the box it's not true! *&%%$%#$%!!
thnx i didn't know that they have dvd players that play mpeg files
what's THE BEST dvd player out there that can play anything ( and pleeeeez do not direct me to the "compatibility website"-looked there already) ..i'm just asking for a PERSONAL opinion thnx
check out the following
http://7925.adahost.com/computer/index.html?loadfile=item12785.html
http://www.avdeals.com/malatan996.htm
http://www.techtronics.com/uk/shop/50-sony-dvp-f21-multi-region-dvd-player.html
and sorry the dvd player i consider best
i can no longer find the site to so can not give it to u
sides it would cost you about 600 $$
the above ones should be about the same but dont know
anyways just do a search for for what you want in a dvd player
like: cdr cd rw vcd svcd pal ntsc dvd player region free macrovision free
and also sorry if u did not what this info but other -
Do you have a max price in mind, or is there no limit?Originally Posted by BeautyAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
you must decode youre avi files to mpeg using TMPEGenc 1.2,then split them in 2 pieces of 500 mb en burn them with nero 5.5 as a vcd to youre cd r or cd rw.
the best cd r`s are vivastar a very cheap brand but it will work on every dvd player even stand alone player`s
dennis
