I just reloaded my capture pc with win2k. its capturing videos
great now except that the sound gets about 1 sec out of synch
per 30min. it never used to do that on win98. I seem to recall
that there was a patch needed for VIA chipsets to keep the bus
from drifting or somthing like that. Anyone know if that file is
what I need to fix the synch prob? or if not, what can I do to fix
it? Im running AMD 800mhz, 300megs ram, 3X40g drives striped.
Im capping straight to huffyuv-2.1.1 AVI and the synch issues
I have are in the AVI before I convert it to mpeg.
Also, where can I find that VIA file I mentioned above?
I didnt see it on via.com
Ha I use 7.5 and it works with no problem and I have AMD 1.8XP with MSI K7t266a chip set mother board.with MMC 7.1 when I capture mpeg 2 and run it with TMPG i get lip sync problems
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 22:00 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
