I got a friend to tranfer all my old vhs movies to dvd but none of them work in dvd players or computer. Well come to find out he forgot to finalize them !!!!argh!!!! He is not answering my calls so can any one tell me if there is any way i can finialize them with a computer program and waht program is best!!!!!!!
Results 1 to 9 of 9
As far as I am aware, the answer is no.
The disks must be finalised in the recorder that created them.
But are you certain they are not finalised ? They could have been created using VR mode instead of VIDEO mode - can you see the files from Winodws Explorer etc ? These will not play in a stand-alone but you should still be able to play them using a software player such as Power DVD.
BTW You should try to make your topic header a little clearer. A simple 'Please Help' will not attract much interest. -
srhewett, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
If you use dvd decrypter to "read" the disc, does it say what it was burnt on or do you know what brand of dvd recorder he had, you can extract unfinalised data using isobuster but lordy is it a painful process. If you can find out which brand of dvd recorder you can "buy" one from a best buy or somewhere and finalise them and then return it or some similiar solution.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Just a guess, but, may work.
if DVDs are not CSS copy protected, and video DVDs are on DVD-R (4.7 GB)
Use ImgBurn. Try on one DVD.
ImgBurn will automatically identify its a video DVD.
1) convert video dvd into ISO file on hard-disk.
2) burn ISO on blank DVD-R back again.
Try in a stand-alone-SVS-Player, see if it works! -
I have had disc's that were not finalized by standalone recorders and one's that would not finalize and i used Isobuster to get the contents off the disc's.
I had to use the pay version, although it would be cheaper and faster.
And yes, an unfinalized disc from a standalone recorder will usually only show up as blank in a PC.
Ripping DVDs to my computer
By sd2005 in forum DVD RippingReplies: 10Last Post: 1st May 2012, 15:32 -
What paint program do you use for your computer?
By johns0 in forum PollsReplies: 26Last Post: 25th Nov 2011, 05:02 -
What format to rip my DVDs to my computer?
By SirMoby in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2011, 21:07 -
Computer Does Not Read Fianlized DVDs
By BillP2 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 13th Jun 2008, 04:13 -
Burned DVDs only play on my computer
By kissy in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2008, 13:48
