so basically to run a setup where a laptop or desktop can run off of battery/solar power...items need would be a battery(deep cycle preferably), a power inverter and a decent solar panel. No China Stuff.
I found this site that had a little pic setup at the bottom of the page that shows the basics on what will be needed, perfect for a novice to understand. It shows a diagram with a boat and RV but I think the idea is is the same.
Solar Site
would have replied sooner but this pc is startin to die lol. It's had a good running life![]()
Results 31 to 32 of 32
You'll also need a charge controller. It help maintain your battery and keep it from overcharge. Overcharging will shorten your battery life. More info than your wanted to know on lead acid battery here:
http://www.windsun.com/Batteries/Battery_FAQ.htm
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
Which to use on a Laptop, the Battery or Power Cord
By Moontrash in forum ComputerReplies: 4Last Post: 7th Jun 2010, 20:16 -
laptop + new battery = no Power
By nick101181 in forum ComputerReplies: 8Last Post: 15th Jan 2010, 14:29 -
How To Choose the Right Power Supply When Building a Computer
By imdaman in forum ComputerReplies: 12Last Post: 27th Nov 2009, 22:37 -
Laptop Power Ports on an airplane
By Jeremiah58 in forum Off topicReplies: 4Last Post: 19th May 2007, 21:30
