I want to make a singe video file with the audio in it. But premiere cs4 constantly keeps exporting audio as additional file. I have tried with the multiplexer turned on as TS and MPEG2. The video file that it exports works perfectly (MPEG2, 25fps, PAL, progressive...), I have even tried to export the audio as mpeg-1, layer I audio.
Thanks in advance
Need more info on the type of file you are dealing with. To me, it looks like a .ts file.
Burning a Blu-ray is the next achievement. ;) -
You don't have a single video file to begin with? So, the program gives you two files and you want to mux them into any container, or do you just want to mux into a .ts file?
I want to mix them into one file, mpeg2 in this case. I tried ts because i read it on some other forum.
Problem solved, I just exported the file as avi and audio was in it. Don't know why mpeg2 splits them in two.
Thanks for the help anyway
Exporting smaller files from small avi originals?
By loiseye in forum EditingReplies: 4Last Post: 17th Nov 2009, 17:38 -
Exporting Windows Mover Maker Audio Files
By ProducerHarley in forum AudioReplies: 0Last Post: 12th Mar 2009, 16:41 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
exporting .m2v source files out of fcp without quality loss
By MacNiles in forum MacReplies: 9Last Post: 17th Aug 2007, 08:39 -
Exporting audio from VideoStudio 9. Possible?
By markannab in forum AudioReplies: 2Last Post: 6th Jun 2007, 20:48
