i was recording a video on my droid and the battery came out (because a raccoon tried to steal it). ive got the 3gp video file but i think it is missing some information because the battery came out while it was recording. ive tried playing it in a host of players, and i tried using all_video_fixer, but the fixed file still wont play. VLC says "No suitable decoder module:
VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this."
is there a way i can save this video? i can post it too if you want a crack at it. thanks in advance!
Wild guess, but could undf stand for Undefined ? i.e. the header does not have the required information regarding the codecs used.
You might be able to fix it with a hex editor by copying the header from a known, good, working file into a copy of the broken file. There are a couple of posts around that tell you how to do this.Read my blog here.
You try repair it with something like video repair tool. Use the trial first and see if it can find some video.
Play Unsaved Video by Mobile Phone
By kamaldeepdung in forum Video ConversionReplies: 1Last Post: 8th Mar 2012, 05:09 -
Cell Phone Shut Down During Video and Video Won't Play
By Chief4Life in forum Newbie / General discussionsReplies: 13Last Post: 17th May 2011, 22:26 -
Wanna Play HD video Clip on my cell phone !
By augustya in forum Video ConversionReplies: 6Last Post: 3rd Oct 2010, 10:43 -
Projector wont play video from various componets.
By Vidmee in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2010, 00:08 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 16:44
