Hello,
I know this issue has been discussed more than once, but it seems that my case isn't quite the same as the other threads I found.
I recently tried to convert a Video TS on my hard drive to an AVI file. While the video does not appear to have any problems, there is no audio at all (the DVD itself offers six different audio options and multiple subtitle options). However, both the AUDIO TRACK(S) and SUBTITLE TRACK(S) field on the main menu screen were completely empty.
I'm including the full log below. Can anyone give me any advice?
---BEGIN LOG---
[11.05.2010 19:25:47] AutoGK 2.55
[11.05.2010 19:25:47] OS: WinXP (5.1.2600).2
[11.05.2010 19:25:47] Job started.
[11.05.2010 19:25:47] Input file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_0.VOB
[11.05.2010 19:25:47] Output file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_0.avi
[11.05.2010 19:25:47] Output codec: XviD
[11.05.2010 19:25:47] Audio: none
[11.05.2010 19:25:47] Subtitles: none
[11.05.2010 19:25:47] Format: AVI
[11.05.2010 19:25:47] Target size: 1400Mb
[11.05.2010 19:25:47] Started encoding.
[11.05.2010 19:25:47] Demuxing and indexing.
[11.05.2010 19:28:27] Processing file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_0.VOB
[11.05.2010 19:28:27] Processing file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_1.VOB
[11.05.2010 19:28:27] Processing file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_2.VOB
[11.05.2010 19:28:27] Processing file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_3.VOB
[11.05.2010 19:28:27] Processing file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_4.VOB
[11.05.2010 19:28:27] Processing file: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_5.VOB
[11.05.2010 19:28:27] Source resolution: 720x576
[11.05.2010 19:28:27] Found PAL source.
[11.05.2010 19:28:27] Source aspect ratio: 4:3
[11.05.2010 19:28:27] Analyzing source.
[11.05.2010 19:34:54] Source has percentage of interlacing in motion areas: 0,00
[11.05.2010 19:34:54] Source is considered to be progressive.
[11.05.2010 19:34:54] Output will contain 151278 frames
[11.05.2010 19:34:54] Using VAQ in XviD
[11.05.2010 19:34:54] Overhead: 0 bytes (0.00 Mb)
[11.05.2010 19:34:54] Video size: 1,468,006,400 bytes (1400.00 Mb)
[11.05.2010 19:34:54] Running compressibility test.
[11.05.2010 19:34:54] Writing the following script to C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\agk_tmp\VTS_01_0_comptest.avs
LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dl l")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrain SSE3.dll")
movie = mpeg2source("C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\agk_tmp\VTS_01_0.d2v")
cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples= 10,aspect=0,threshold=34,samplestartframe=0,leftad d=0,rightadd=0,topadd=0,bottomadd=0)
fixed_aspect = 1.06666666666667
c_width = width(cropclip)
c_height = round(height(cropclip) / fixed_aspect)
input_par = float(c_width)/float(c_height)
input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0)
out_width = 704
out_height = round(float(out_width) / input_par)
hmod = out_height - (floor(out_height / 16 ) * 16)
out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
autocrop(movie,mode=0,wmultof=4,hmultof=4,samples= 10,aspect=new_aspect,threshold=34,samplestartframe =0,leftadd=0,rightadd=0,topadd=0,bottomadd=0)
LanczosResize(out_width,out_height)
RemoveGrain(mode=2)
SelectRangeEvery(300,15)
[11.05.2010 19:40:47] Duration was: 5 minutes 53 seconds
[11.05.2010 19:40:47] Speed was: 21,41 fps.
[11.05.2010 19:40:47] Compressibility percentage is: 84,02
[11.05.2010 19:40:47] Chosen resolution is: 720x400 ( AR: 1,80 )
[11.05.2010 19:40:47] Predicted comptest value is: 78,87%
[11.05.2010 19:40:47] Running first pass.
[11.05.2010 19:40:47] Writing the following script to C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\agk_tmp\VTS_01_0_movie.avs
LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.d ll")
out_width = 720
RemoveGrain(mode=2)
[11.05.2010 20:58:57] Duration was: 1 hour, 18 minutes 10 seconds
[11.05.2010 20:58:57] Speed was: 32,26 fps.
[11.05.2010 20:58:58] Expected quality of first pass size: 78,15%
[11.05.2010 20:58:58] Running second pass.
[11.05.2010 22:50:59] Duration was: 1 hour, 52 minutes 1 second.
[11.05.2010 22:50:59] Speed was: 22,51 fps.
[11.05.2010 22:51:00] Splitting video into: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_0.cd1.avi
[11.05.2010 22:51:58] Splitting video into: C:\Documents and Settings\owner\Desktop\Filme\krotitele_duchu_cz_or iginal\VIDEO_TS\VTS_01_0.cd2.avi
[11.05.2010 22:52:47] Job finished. Total time: 3 hours 27 minutes 0 seconds
Results 1 to 15 of 15
Open the file in MediaInfo, then change to Tree View. It will list all the stats on the file, including the video and audio codecs used, number of streams and their details etc.
It is also worth testing with something like VLC or The KM Player, which don't use system codecs. This can help narrow down if the problem is with the original encoding, installed system codecs, or the current player.Read my blog here.
There doesn't appear to be any information related to audio on the tree view. The only codec listed (under VIDEO) is XVID.
Apparently AutoGK didn't see any audio to begin with. So, apparently you didn't decrypt it properly. I'm guessing DVD Decrypter or something that decrypted the entire DVD rather than just the video you wanted. My suggestion is to start over, this time decrypting only the video and not the entire DVD. The first part of the VOB didn't have audio. Done right that shouldn't happen.
The problem is that I don't actually have the DVD that this was ripped from. All I've ever had is the files. When I run them on the computer as a DVD, I have no problems at all. The reason I'm trying to convert this is that it seems to be the easiest way to take this PAL video and convert it to NTSC.
AutoGK doesn't convert PAL to NTSC. How is this the easiest way? If you're thinking you know of programs that can take an AVI and convert it to NTSC DVD, there are programs that can do the same for a PAL DVD, without the intermediate step of ruining it by converting it first to an XviD AVI. Or you can just buy yourself a cheap DVD player that can do the conversion directly on the PAL DVD.The reason I'm trying to convert this is that it seems to be the easiest way to take this PAL video and convert it to NTSC.
If I have an AVI file, I have software that will burn it in any of the major formats, so I can just select NTSC and it will burn it as NTSC (obviously a suboptimal solution).
I had actually looked around for software that would do a direct PAL-NTSC conversion on a VIDEO TS, but all I could find were forum posts claiming that no such software existed, and that it was an extremely complex process. If you know of something that can convert directly, I'd be very interested. -
There are several guides listed here:
https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=&how...or+List+Guides
I'm sure others know of other ways, some perhaps using all-in-one programs. Of course, you'll lose the original menus, but you're doing that anyway using your method. For example, I'm fairly certain steps 8 and 9 of this guide about converting Blu-Ray to NTSC DVD can be adapted to choosing a PAL DVD as your source:
http://adubvideo.net/how-to/convert-bluray-dvd-avstodvd
In Step 3 you'll want your MPEG-2 encoder to be HCEnc.
Sound doesn't convert using AutoGK
By Looler in forum Video ConversionReplies: 6Last Post: 25th Sep 2010, 21:40 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
no sound with fairuse wizard encodes
By ubamous3 in forum DVD RippingReplies: 0Last Post: 28th Mar 2010, 19:06 -
AutoGK and 5.1 sound
By WebMaximus in forum DVD RippingReplies: 3Last Post: 27th Sep 2008, 08:01 -
AutoGK sound issues
By SpaceMonkey52 in forum DVD RippingReplies: 7Last Post: 26th May 2008, 03:37
