Ok, so I'm not completely ignorant to video conversion. . .and I know how to simply concert VOB's to AVI's. I'm looking for a specific solution.
When I see versions of tv-shows on bit-torrents. . .the AVI always seems to be about 300 - 400 MB. And the video quality is DAMN good.
I want to convert my Smallville DVD's to individual AVI's for use in XMBC. I'd like to convert a 1.8 GB vob file to an AVI of 300-400 MB with good quality.
So basically I'm trying to figure out how those guys who rip TV shows get the AVI down to 300-400 MB with such good quality.
Any help would be apreciated.
NOTE: I know how to get the files down to a VOB. No need to explain that. I just need to now what software to use, codec, generic procedure.
Every time I make an AVI it winds up being about the same size as the damn VOB.
	I see this claim all the time, but objectively, it simply isn't true. Files compressed down to 300 MB are reasonable, with several caveats.
 1. The resolution needs to be no wider than 640 pixels.
 2. Dark scenes or high action scenes will exhibit some artifacts.
 3. They can in no way be called "DVD quality" or even "Near DVD Quality"
 Simplest method is to use AutoGK or AVI.net, which will work out most the nitty gritty for you. You can do quality or size based encoding with these tools.
 If you want to do it manually then learn some avisynth and use virtualdub for re-encoding.
 As for filesize, the universal rule for digital video is
 Filesize = Running Time X Bitrate.
 Given running time is a constant, you have to reduce the bitrate to reduce the filesize. Use a bitrate calculator to work out what bitrate you need.Read my blog here.
	The simplest method is to rip the dvd to iso using dvddecrypter then use fairusewizard to convert to avi.
  Newbie converting DVD to AVIBy nuggett_aus in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 06:31
  Newbie questions on converting avi to mpeg2 and dvd authoringBy mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 14:08
  Newbie Help - Very Large AVI file to DVDBy Lebowski25 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 22:42
  I need a guide to convert avi to dvd plz (newbie topic) helpBy Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 08:03
  Newbie: need basic explanations: From AVI to home dvd playerBy Raoul777 in forum Newbie / General discussionsReplies: 3Last Post: 21st Aug 2007, 23:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
