can someone please tell me how to crack region code on avi files to burn to dvd?
i have downloaded a few avi. files and i have used ConvertXtoDVD 4 to burn them to dvd so i could watch them on my tv. when i load them i get a restricted cannot play in this area message.
i can play them using vlc on my computer so i know the files are okay, but my tv is so much better than my monitor.
any help i would be very grateful.
thanks in advance,
wibureduke
AVI videos do not have region codes.
You're likely trying to play PAL-format videos on an NTSC DVD player that cannot play PAL-format video. I don't use ConvertXtoDVD, so I don't know if it can do a conversion from PAL to NTSC, but there are additional topics on this forum about that type of conversion.If cameras add ten pounds, why would people want to eat them? -
AVI files do not have regions. You do not have a region problem.
What you do have is a format problem, and a DVD player that gives a piss-poor message when this occurs. My guess is that it is a Sony player.
There are two formats : NTSC, which is used in the US, Japan and other parts of the world, and PAL, which is used in Australia, the UK and much of Europe.
You don't say where you come from, but the issue is that you have created a disc that is the opposite format to where you live. You can change the settings in ConvertXtoDVD. It has three options : PAL, NTSC, and Auto. PAL means whatever goes in comes out PAl. NTSC means whatever goes in comes out NTSC, and Auto means if PAL goes in, PAL comes out, if NTSC goes in, NTSC comes out.
Note : if you don't use Auto then you risk quality issues by forcing format conversionRead my blog here.
SONY BDP-S350 how to crack region codes from its own menu?
By madfogs in forum DVD & Blu-ray PlayersReplies: 24Last Post: 26th Aug 2015, 18:00 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Region crack reversal
By Che_qwerty in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jul 2011, 08:48 -
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 11:24 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 04:37
