My cd/dvd drive went bad, and I need to replace it I opened the computer case and seen that there are no gray flat ribbon cables. What type of drive do I need?
you have 2 basic choices, ide or sata. ide would be the big 40 pin cable - sata is the much smaller cable. remove the drive and it should have a label that says either ide or sata.
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 01:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 21:03 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Bad hard drive, or something else?
By capman21 in forum ComputerReplies: 4Last Post: 23rd Aug 2008, 02:59 -
Bad Hard Drive - Not!
By videobread in forum ComputerReplies: 4Last Post: 11th Sep 2007, 15:47
