So I'm dumb, and can't figure this thing out. All I want to do is use this program to take a 18GB M2TS file and split it into chunks which will fit onto a FAT32 memory card and then play successfully and seamlessly as a sequential video on a PS3. It sounds like this is the program for that.
It's got a window that indicates "cuts". But with no documentation, and a total dearth of successfully answered questions about the program in various forums, I'm at a loss. I can "add new area from the current selection" if I have a range selected (some several frames of the video at least). This would appear to be a great way to snip OUT video, but that's not what I'm after here. I just want it divided into sequentially-playable 4GB chunks.
Simple question, probably simple answer. Anyone? ;p
TsMuxergui will split files by size very easily. Open the program. Go to the split&cut heading and you can split by duration or size.
Tony
TSSniper - Filtergraph error
By MACKerMD in forum EditingReplies: 24Last Post: 21st Jan 2014, 14:43 -
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
Split video files
By dharmil007 in forum EditingReplies: 19Last Post: 29th Oct 2011, 11:19 -
Is TSSniper still under development?
By The Realms of Gold in forum EditingReplies: 4Last Post: 29th Apr 2011, 18:33 -
Split files
By Jomapil in forum ComputerReplies: 8Last Post: 27th May 2009, 19:45
