Results 1 to 14 of 14
    Mar 2006
    I've tried a few apps to do a genuine save of videos online.
    But some videos seems seem so ebmedded and hard to download, that I've given up.
    I know where are some video screenshot apps, but they are always pricey and the videos tend to me quite large in size.
    Any ideas? thanks!
  2. StreamTransport can download almost all online videos. Even encrypted RTMPE sources.
    VirtualDub is free and has the ability to capture from the screen.
    Mar 2006
    J, thanks, can it download a couple of these videos to my desktop?:
    http://www.lipitor.com/personalStories.aspx
  4. StreamTransport had no problems downloading from that site. But that site is easy. Even Firefox with its Download Helper plugin can download from there.
  5. Option + Command + A in Safari to open up activity window. Locate the the video you are viewing and Option + Double Click video playing (3MB of 22MB for instance). Once you do that you'll find it in /Downloads folder usually as an .mp4 video file once it finishes downloading.
    Adding a screenshot to more clearly illustrate it.
    Mar 2006
    MR, thanks sounds great,
    where is it in Activity Monitor -- I cannot see it.
Name:	Screen shot 2010-05-11 at 8.12.39 PM.jpg
  7. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Originally Posted by kevs View Post
    Where is it?
    In Safari's Window menu is an option for Activity, which shows all elements (html, css, images, multimedia) from currently open webpages. Find it there. The expected larger file size should help identify the video faster: look for "MB" instead of "KB".
    Mar 2006
    Don't see it there, see screenshot, boy they don't make this easy!
    you figure it would be highlighted or something.
Name:	Screen shot 2010-05-12 at 10.44.13 AM.jpg
  9. You have to start playing the Video and then download it. Guess I should have mentioned that. edit: (Locate the the video you are viewing) I did mention it "you are viewing". Anyway hide all the other windows by collapsing them by clicking on the down arrow sign in the Activity Window in Safari. It will move sometimes as it refreshes frequently but if I am able to screenshot it quick enough with it highlighted you should be able to quickly OPTION + double click it.
  10. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    4th from the bottom, URL ends with ".flv", 9.5 MB.
    Originally Posted by mrbass View Post
    ... you should be able to quickly OPTION + double click it.
    Alternatively, select the line with the file you want, copy that (Cmd-C), bring the Download window to the front, paste (Cmd-V); and the download begins.
    Mar 2006
    Case, thanks found it and downloaded, but there is no sound to it.
  12. The FLV file I downloaded had VP6 video and MP3 audio.
    Mar 2006
    J,
    I don't know what that means, but someone suggested I download VLC and Perian to get sound and now I'm getting sound although I don't understand why.
