Hi....I realized this might be a real easy ?, but I havent figured it out yet. I capture VHS through my ATI Radeon at 720x480 mjpeg. I then used CCE to encode it to mpeg2. But when I playback the mpeg 2 on my hollywood card, the left and right ends get chopped off on the TV. How can I fix this...I tried changing the playback settings in the DVDstation controller, but didn't have any luck...Is there something I'm missing?
Also, whenever I use CCE to encode at something other than the full resolution (i.e. something like Standard VCD settings or 1/2 DVD) my mpeg looks horrible...It flickers and is full of blue squares...Any ideas why this is happening also?
Thanks for any help
-Strep
How much is chopped off on the TV? What happens if you play the MPEG with a software player?
Truman,
Looks like theres ~5-10% of the total picture clipped off from the right side and about the same amount clipped off from the left side. When I play on a software player, it's all there. In fact, when using the Hollywood DVDstation player, when I click on the Monitor-to-TV playback button, everything appears fine on my monitor....It's only when I try to output to my TV that I'm missing the sides.
Hope this info helps. Thanx again
-Strep
Getting perfect AR on wide TV?
By terrypin in forum Authoring (DVD)Replies: 7Last Post: 15th Sep 2011, 17:08 -
Wide 9:16... What Am I Doing Wrong?
By GRAMOPHONE in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2010, 08:34 -
Wide screen
By breeze9 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2007, 23:31 -
Low quality AVI playback after formatting my computer, any ideas please?
By CBR600 in forum Newbie / General discussionsReplies: 8Last Post: 27th Jun 2007, 03:45 -
wide screen
By ht0160 in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 17:52
