I am trimming an MP4 video file in AVIDemux. Is there a way to trim with out having the video being re encoded? Or if it has to be re encoded when I trim ... is there some setting that will re encode using the exact same specs that the original clip was encoded with??
Thanks!
Bob
Results 1 to 11 of 11
It wont be reconverted if you set video and audio to copy.
In avidemux, did you cut on keyframes?
You should be able to cut it in quicktime pro as well -
I frame
you can use the "<<" and ">>" buttons to advance to the nearest one, use those keys to navigate
did you set video , audio to copy , format to .mp4 , and save with extension (e.g. "myvideo.mp4") -
Yep, I was using I frames, Copy video, Copy audio and Format MP4 and still the error. I guess I will just put in settings and get it to recompile the video to get around the error. Tks all!
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Trimming subtitles along with video
By msmirjat in forum SubtitleReplies: 2Last Post: 6th Sep 2011, 02:08 -
File has more frames after trimming.
By sambat in forum EditingReplies: 0Last Post: 27th Jul 2011, 07:43 -
Mac Encoding/Trimming
By Blotttt in forum MacReplies: 2Last Post: 28th Mar 2011, 17:52 -
Trimming and editing
By chasalex in forum EditingReplies: 2Last Post: 4th Oct 2010, 11:44
