I know how to add silence to the end of a track using Audacity, but I haven't been able to figure out how to add silence to the beginning. Putting the cursor at the beginning and trying to "paint" a time-span selection to the left (before 0.0) doesn't work. Anybody know?
'Edit' > 'Move cursor' > 'to track start'.
'Generate' > 'Silence' and insert the value. -
sambat -- that worked perfectly. I didn't know you could insert a fixed value in the "length" box, I thought it was just for display of the time selection "painted" with the cursor.
Thanks.
help needed want to add 30 secs vid beginning and ending,is this possible?
By mission-uk in forum Authoring (DVD)Replies: 4Last Post: 16th Oct 2010, 11:51 -
add true hd track to TS file
By xenotox in forum Blu-ray RippingReplies: 2Last Post: 31st May 2009, 22:50 -
Add new audio track and keep menus
By Kim Dung in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2008, 05:47 -
How to add a splash screen at beginning of avi
By Overfloating in forum EditingReplies: 3Last Post: 20th Jan 2008, 04:37 -
Add seconds on to track?
By sbuckmybballs in forum AudioReplies: 4Last Post: 23rd Dec 2007, 21:35
