Guys
I recently bought new Samsung Blu ray DVD player and need to use to watch Netflix movies but according to manual I need to purchase Samsung LinkStick Wireless USB 2.0 Adapter WIS09ABGN and it seems to very pricey. Do I have choice besides purchasing this unit? Or is that any other generic unit will support to stream movies from Netflix? I would appreciate your feedback on this matter.
Thanks in advance
Unless the Samsung is very picky with the brand and model USB adapter, you might try one of the Edimax adapters. I've used them on my WDTV Live and they seem to configure easily. I've streamed HD video across my wireless system, so bandwidth isn't much of an issue if you have a good signal. This one is fairly inexpensive. http://www.newegg.com/Product/Product.aspx?Item=N82E16833315088&cm_re=edimax_wireless_...-088-_-Product
What usb wireless N adapter to get?
By neworldman in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 09:49 -
Wireless usb adapter on WD TV
By kyrcy in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Apr 2010, 18:50 -
Wireless Adapter
By Sakuya in forum ComputerReplies: 13Last Post: 21st Dec 2009, 23:40 -
Sprint/Novatel U727 USB Wireless Internet Adapter
By ahhaa in forum ComputerReplies: 2Last Post: 18th Dec 2008, 15:49 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
