hi
i d/l divx 412 and 311 because i want to use tmpgenc. how do i use these programs with tmpgenc? i extracted the files and ran the setup . do i have to do more to run divx412, 311 ?
go to my topic i made they is a link for nimo codec pack it 5mb but it is worth it
the newbie paul aged 13 -
do not worry nimo has the codecs u need i had probelms useing the program with the 2 dvix codecs but when i installed this it started to work
MAKE SURE U DO NOT INSTALL MX900 (something like that) IT WILL **** UR PC -
thanks i'll try it and see what happens .
can i delete divx 412 and 311 , when i d'l nimo ? -
ok i d/l nimo and confg. divx af and divx g400 . will this progams run automatically with my wmp7.1 ? or do i have to run somthing of nimo ?
with win amp i am not sure if it did not play the vid before it should now like in media player it never used to play but it does now so it should do i do not have win amp
How to encode to DIVX4 (.ASF) ???
By unicodE in forum Newbie / General discussionsReplies: 5Last Post: 4th Sep 2008, 20:48 -
divx4 to dvd
By havn't a clue in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 13:30
