I have MPEG2 videos (taken from DVD) and i want to resize them, watermark and convert/render to h.264 FLV.
How can i do that?
Results 1 to 10 of 10
If you just want to watermark with a text logo you can use SUPER, load your dvd vob files, select flv as container and h264 video and aac audio, click on DirectShow Decode and click on the D-button next to it to add the watermark. Convert.
If you want an image logo
Familiar with avisynth? Then use it. See https://forum.videohelp.com/threads/305986-adding-watermark-while-ripping .Export to a mp4 with h264 using megui. mp4 works fine in flash also.
If it's too complex then you can try virtualdubmod, https://forum.videohelp.com/threads/191496-Put-a-custom-watermark-on-your-video . Export as avi and convert to mp4 or flv with another converter. -
you can try format factory. I think that outputs to flv. I know I've converted to other formats with flv as the input source so I think it can output as well. Though the watermarking you'll have to do with other programs.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
yes aac audio is fine
are you sure you *need* flv container? many flash front ends work fine (some better) with .mp4 container
to mux into flv container you could use ffmpeg (command line tool)
ffmpeg -i input.flv -vcodec copy -acodec copy output.flv
if this is for streaming web , you need to inject metadata or it won't play right away (will need to be downloaded completely first). You could use flvtool++ , flvtool2, yamdi, or flvmdi to do this -
I will need to use the FLV videos for streaming on FlowPlayer and other flash players, as i thought, the injection is needed for "seeking" feature in the video, to fast forward to some other parts or so, but in my case, it wil be like 1 minute clips, most players (flash) are buffering some video data before showing, i'm not sure if i really need the injection
are you using true streaming (rtsp) , psuedostreaming or progressive download (http) ?
most common and least expensive is http progressive download
initial buffering is a server side delay , this is different than waiting 100% for download before it plays. You set this value when setting up the code. e.g. on youtube or related sites, there is a short delay, but you can start playing immediately. If there was no metadata, or moov atom wasn't at beginning, you would have to wait until 100% downloaded before it starts to play
mp4 in general works fine in flowplayer for streaming, for progressive download case. Youtube uses .mp4 for their pseudostreaming
mp4 from vegas does not (have to wait until 100% downloaded), because metadata (moov atom) isn't at the beginning by default. To get around that you have to either remux from mp4box (yamb) or mp4faststart
http://www.datagoround.com/lab/ -
Thank you for explanation.
So, it means that if i want to render mp4 video and them cut it to clips, i will need to use mp4faststart for every clip, right?
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 16:22 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 11:41 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
