All 3 shots are taken from the same video source.. (.avi , x264 : 1280x720)
anyways, picture on happens the frame before picture 2
, in picture 2 you can see the left over of kyon's head and tie "burned" on the door..
this happens when i run the video through mpc-hc
throwing the same exact video at virtualdub shows no artifact what so ever..
anyone knows what did i do wrong in my player?
its running ffdshow codec with no shader running
i tried both with full error correction and none..
Results 1 to 16 of 16
this is a type of "ghosting", where there are remenants from either the previous or next frame
it might be in the source (I suspect), or sometimes it occurs when you use directshowsource (which isn't frame accurate) with heavy temporal filters
Are you sure vdub doesn't decode with the artifact ? Try changing ffdshow version or another decoder like divx h.264 for directshow
What vdub decoder are you using for h.264? ffdshow vfw?
Can you post the sample -
not sure , it works fine on everything here on this computer (xp 32-bit)
mpchc, vlc, smplayer, divx h.264 decoder etc....
when you render the file in graphstudio , what does it say? did you use clsid's filter tweaker tool to override default ms decoder? -
you can't enable that in mpc-hc , because its a directshow player
vdub uses vfw interface, not directshow
ffdshow has both a directshow and vfw version
try changing ffdshow versions (disable in the configuration, and try divx h.264 - i.e. graphstudio shows divx h.264 now instead of ffdshow)
something is wrong with your directshow system decoding . Maybe post at doom9 and ask for help there
Artifact in U-matic (3/4") capture
By JVRaines in forum Capturing and VCRReplies: 53Last Post: 21st Aug 2012, 10:50 -
Handbrake "Burned in" Subtitle Problem
By Roxas13 in forum SubtitleReplies: 0Last Post: 4th Apr 2012, 05:57 -
PC "thinks" burned media is blank
By joelson in forum MediaReplies: 12Last Post: 28th Jan 2012, 19:19 -
Cleaning Up Weird "jittering" in the background
By cfelicio in forum RestorationReplies: 9Last Post: 8th Jul 2011, 08:28 -
"resume play" feature for dvds burned by dvd recorders (pioneer d
By barninga in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Nov 2007, 03:11
