Hmmnn... not sure if there's one that will retain the tags and let you normalize. Then again, I am not very familiar with AACGain. But another option would be to convert the AAC files into a different format (one which still retains their true quality), such as AC3 using WinFF or VLC converter.
I've found it helpful, and I'm sure it would work for you as well. If however you NEED the audio files to remain in AAC format, then I'm sorry for wasting your time... as this post won't really help you.
Either way, I figured I'd try and at least give you a response for your thread, considering no one else has tried to help out
Mini Guide: Normalizing Audio for Multiple AVI files
By Soopafresh in forum AudioReplies: 456Last Post: 9th Dec 2016, 22:26 -
Can someone make me a ffmpeg file for normalizing mp4 files? I am Clueless.
By xrayengineer in forum DVD RippingReplies: 2Last Post: 3rd Feb 2011, 19:46 -
Problems about aac audio in TS files
By ihmcjacky in forum Video ConversionReplies: 4Last Post: 30th Nov 2010, 01:24 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58 -
Normalizing with avi-gain- 2 files fail to appear in the "completed&qu
By DaneClark in forum EditingReplies: 1Last Post: 13th Jul 2009, 00:45
