Hi,
I am trying to Encode a video file (in VOB format, 4:3 aspect ratio) to AVI file. The original VOB file is a full screen video, with size as 720x480. I am using AutoGK for my conversion process. There are no black bars in my VOB file. If I try to convert the VOB to AVI, AutoGK automatically takes up resolutions like 720x544 means it will increasing it's height automatically.. Is it ok? because original source has height as 480.
Even if I decrease the width to 656, even then height is at 496 (e.g AutoGK takes the resolution as 656x496) again indicating an increase in height from the original source.
But if I take the width as 640, then I get the resolution as 640x480 and in that case the height is remaining the same. But isn't the decrease in width from 720 to 640 too much if the height remains the same?
Kindly suggest which resolution should I go for. thanks in advance
If you're making the AVI for a specific size (like 700 MB or 1400 MB), then it's best that you allow AutoGK to choose the width so it can get the best quality for the size you choose. If you're running single passes for a target quality percentage and don't care about the final size, then it doesn't really matter how you set the width, but there's nothing wrong with setting the width for 640.
It has to be resized as 720x480 (a ratio of 1.5:1) isn't the final output ratio when being played as a DVD. A 4:3 DVD automatically gets resized by the player to some 1.33:1 ratio, one such as 640x480. An AVI is often resized while being encoded.But isn't the decrease in width from 720 to 640 too much if the height remains the same?
Can't change subtitle size on avi file
By jlulu1979 in forum MacReplies: 0Last Post: 11th Aug 2011, 18:41 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
.avi to .VOB format - without changing size & quolity
By akakiami in forum Video ConversionReplies: 5Last Post: 19th Dec 2009, 11:48 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
avi to vob size comparison
By thai1 in forum Newbie / General discussionsReplies: 6Last Post: 4th Sep 2008, 10:27
