  1. Authoring throws me that error. I've tried exporting (from MPEG StreamClip) as MPEG, Headed MPEG, MPEG with MP2 audio… nothing works.
    I wanted to add subtitles, but I won't even mention that in this thread.
    MediaInfo says:
    General
    Complete name : /Volumes/XXX/_Movies/XXXX/headed.mpeg
    Format : MPEG-PS
    File size : 220 MiB
    Duration : 3mn 56s
    Overall bit rate : 7 815 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Duration : 3mn 56s
    Bit rate mode : Variable
    Bit rate : 5 996 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : NTSC
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.579
    Stream size : 169 MiB (77%)
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Format_Settings_ModeExtension : CM (complete main)
    Duration : 3mn 55s
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 12.6 MiB (6%)
    Audio #2
    Format : AC-3
    Duration : 3mn 55s
    Bit rate : 384 Kbps
    Stream size : 10.8 MiB (5%)
    Audio #3
    Format : AC-3
    Duration : 3mn 55s
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Stream size : 5.40 MiB (2%)
    Audio #4
    Format : AC-3
    Mode : Dual Mono
    Format_Settings_ModeExtension : VI (visually impaired)
    Duration : 3mn 56s
    Bit rate : 640 Kbps
    Sampling rate : 44.1 KHz
    Video delay : 13ms
    Stream size : 18.0 MiB (8%)
    Oct 2005
    666th portal
    one of your audio's is 640kbps and 44.1khz - both of which are illegal for dvd.
