hi!
I have some mkv files wic has 1080p video and DTS audio. Since I don't have blueray burner and my PC won't play 5.1 channels, I am wondering if it is possible to make a dvd preserving the quality (1080p and dts).
is it possible? I don't care if I should use 5 discs.
I tried a guide to convert to blueray and burning to a DVD disc to be played on blueray player but the result was not good at all.
thanks a lot!
Yep, you can burn blu-ray/avchd video on a dvd. Try multiavchd. But it wont work on all standalone bluray players though.
Images/Screen overlapping reminds me of a problem Ripbot had (or still has) when you try to play a 1080p video that wasn't true 1080p. Same with 720p. For example. 720p should be 1280x720, yet many videos will actually be something like 1280x680 or whatever.
So that's why whenever I get an .mkv that is not the full 720p or 1080p then I use ripbot to re-encode...which sux because that's many hours wasted. If the file size is under 8GB (DL) then I'll just use tsmuxer to author it to AVCHD to play on a DVD disc in my bluray. Tsmuxer doesn't cause the overlapping problem but Ripbot does.
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35 -
Is my PC too old to play 1080p video?
By aer in forum Newbie / General discussionsReplies: 9Last Post: 17th Sep 2010, 18:56 -
1080P Playback On My PC? And WD 1080p Player Need A Expert!
By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 12:43 -
edit video hd avc 1080p
By miss in forum EditingReplies: 2Last Post: 20th Jul 2009, 10:21 -
HDV 1080p Im Looking for 1080p HDVs.
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 16th Nov 2008, 21:05
